My Zcars MINI build
My Zcars MINI build
I will update this thread as work continues.
Page 2 post 33 for more picts
Page 4 post 80
Here is Angus when I bought him about 6mo. ago.
He started as a 75 Leyland 1000. Bought him for $2000. He had very little rust except for the back seat area. For my use I didnt need it out it went. He'll never be the same again...
Stripped him down and started cutting him up for the conversion. Gotta love the plasma cutter for quick work on metal. I will be cleaning it up as soon. Should be ready for the acid dip by next week. Then off she goes.
Stock Acura VTEC K20z1 engine from a US RSX type S
Engine has been torn down and internally everything replaced. Block painted and covers polished. Manifold and intake are polished as well just not on the engine yet. AC and power steering deleted.
Stay tuned more to come. Next its off to get acid dipped and coated then the subframe should be here and the fun begins.
Page 4 post 80
If you own a plasma cutter, you're simply in a different league than me. But thanks for the vote of confidence... personally I have no illusions about my ability to swap an engine. Maybe one day I can help with such a job or something - I have a cousin that seems confident that the job can be tackled successfully, and at a far lower cost than some of the Mini VTEC specialists charge.
Plasma cutter.......borrowed. Welder is mine just bought it. And you can do the same thing with big grinder. However I just wanted to use the plamsa such fun! Swapping the engine not too bad actually I bought a long block. Had a import friend of mine redo everything with me so I can see what is going on.Sent the wiring harness to Minitec and let them do what they do best.
There are many frames out there that are up to the job. But, the rear engine conversion is a bit more work.
Z car = Z car prefabbed rear subframe methinks...part of the package.
A stock K20Z1 = ~ 201 HP @ ~ 1500 lbs rear wheel drive. Short wheel base + absurd power to weight ratio = grins, grins, grins.
For gravity bong effect add super charger but make sure the life insurance policy is paid.
Look forward to the progress! Please keep the photos and info coming as they are much appreciated.
Best wishes!
Best wishes!
Yes, please do keep us updated on the progress of your build.
I've been kicking around the idea of going with Pro-Motive's R1 Kit since I like the idea of keeping the Mini fwd and not having to do any cutting.
sounds cool......if i had the money i would do this to my roadster since the back seats are already gone and the back area needs a bunch of work.......good luck with the build.....looks like fun
All I can say is OMG .
Geez, I was just about to start a fundraiser thread to keep Meno's K-series outfitted with rubber... You're gonna really need help! I saw a video a few months ago showing some guys lowering the shell onto a full tube frame chassis (I can't remember, but I think it was inside the z-cars shop). Pretty damned cool. Has anyone engineered an AWD version? Seriously, with that kind of power, AWD would be the ticket.
You dont need to tell me about that. This kit was around 7,000..............................pounds. You do the math.
