MINI Cooper MINI Cooper specs
MINI Cooper MINI Cooper Forums MINI Cooper Pictures
Mark Forums Read MINI Cooper radio MINI Cooper latest news
Go Back   North American Motoring > MINIs in General > Classic Mini Talk
Sign in using an external account
Register Forgot Password?
Welcome to North American Motoring !
Welcome to North American Motoring,
» Latest Main Topics
Advertisement
Thread Tools Search this Thread
Old 08-21-2007, 08:07 AM
rfrink rfrink is offline
Gallery
What is a "Rod Change" tranny?
Here are 2 photos that I swiped off Ebay of transmissions.... The lower photo seems to use a floor mounted shifter with a linkage rod...and the upper photo has the shifter mounting directly in the transmission housing.
What's the background on this? Are they interchangeable with any given body shell and/or subframe? Maybe I just can't see enough detail in the lower photo that is hidden by the subframe...but are these different?
http://www.clubcobra.com/photopost/data/500/turn3-2.jpg
Rob Frink | Columbus, Ohio | Superformance MKIII #1429 | '04 Mini Cooper | '60 MK1 Cooper S replica |
Old 08-21-2007, 09:02 AM
Madoc's Avatar
Madoc Madoc is offline
Gallery
The top photo is of an early gearbox. The long shift lever was called "Magic Wand" by the sales boffins at BMC. The second photo looks like a rod change gearbox that came on later Minis and used a shorter, more straight up shifter. The shift lever was connected to a rod that went into the gearbox. Rod change boxes are known for leaking around the rod seal. Coopers used a "Remote Control" gearchange. Straight up type shifter that was connected to long box with the shift linkage inside. Check out some of the vendor's catalogs for some good drawings of the gearchange assemblies used.
Old 08-21-2007, 09:49 AM
ImagoX's Avatar
ImagoX ImagoX is offline
Gallery
I don't believe they're interchangable... At least, I've never seen conversion kits for sale at any of the vendors (someone correct me if I'm wrong on that please). Rod change shifters are located further aft in the cabin, making for a more modern feeling, but people swear alternately by both systems.
Madoc is right about the rod change seal leaking but don't let that bother you too much - I had to swap out mine after owning my Mini less than a month but did so pretty easily. Luckily it's a really cheap kit (comes with a new seal and a special bushing and dust cover to keep everything aligned and in good shape) and is fairly easy to install with the right tools and a bit of spare time.
http://www.northamericanmotoring.com/forums/signaturepics/sigpic25457_3.gif
~Matt Cook | Dublin, Ohio | '92 Classic Mini Sprite: "Fiona" + Purple Haze 2005 MCS Cabrio: "Dawn". See old MODs from "Nano" HERE - post #166 - many with How-to links!
What's new with Matt? Read more at: http://bloodmagicbooks.blogspot.com/
Old 08-21-2007, 10:42 AM
Agro's Avatar
Agro Agro is offline
Coordinator :: Sin City MINI Club & AMVIV
Gallery
From what I've read, they are somewhat interchangable, but swapping from 1 type to the other involves cutting a new hole in your floor or firewall for the shifter shaft, plus installing the necessary gearbox mounting points.
It's not a straight swap, but it's far from impossible.
2003 LY/B MCS. 15% pulley. K&N HAI. One-ball exhaust. Fireballed ECU. Yellow tinted & stone-guarded factory rally lights. Black scoop, grille & boot handle. Yellow roof stripes & antenna. Rubber chicken antenna topper.
Would I get better milage if I had less fun?
Old 08-21-2007, 03:24 PM
Latka's Avatar
Latka Latka is offline
Gallery
The magic wand comes out much closer to the firewall, so as Agro said you'll end up with a big hole!
Rod and Remote are *much* nicer to drive than the 'ole pudding stirrer that the 850s had.
Old 08-21-2007, 04:36 PM
AZ850 AZ850 is offline
Gallery
The mini that I am looking into has the "magic wand" shifter and it is an 850.
Old 08-22-2007, 09:55 AM
Madoc's Avatar
Gallery
Quote:
I've been told that it truly is magic if you get it to slot into the right gear!
I like the idea of an early Mini - especially if you plan to preserve it as an example of the first of the breed. I'm told by people who know a lot more than I do that the later ones are easier to "improve".
Old 12-16-2007, 11:49 AM
rskotl's Avatar
rskotl rskotl is offline
Gallery
how do I know which one I have?
Old 12-16-2007, 12:13 PM
Latka's Avatar
Gallery
Look under the car where the shifter linkage comes out the back side of the engine. If you see a metal box running the length of the linkage you have a remote tranny. If you see two rods, you have the rod-change. If you look in the car and you see the gear lever coming out of the firewall and then angling up you have the "magic wand" type.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
MINI CooperMINI Cooper PrivacyMINI Cooper Terms of UseMINI Cooper Guidelines MINI Cooper Advertising The North American MINI Cooper Community
  MINI Cooper news, forums, FAQs, and reviews for enthusiasts and owners of the North American MINI Cooper
 Copyright © 2002-2008 North American Motoring. All Rights Reserved.     Powered by vBulletin and vBulletin Plugins by Drive Thru Online, Inc.
North American Motoring is an independently operated web site supporting MINI owners and enthusiastsworldwide. As such it has no official relationship with MINI USA, BMW AG, or BMW of North America.All original artwork and design is Copyright © 2002-2004 North American Motoring.
Admin Account Passwords
Search Engine Friendly URLs by vBSEO 3.5.2
