Just got new "normal" tires put on the Cab! What a friggin' difference!!! So much smoother & quiet ride. Recommend to anyone needing to replace the overly expensive and quickly worn run flats if they came with your Coop!
cant wait. at the rate im going mine will be toast by the end of summer. probably will have about 25K+ by then and surely dont want them to touch snow again.
I too just replaced my RunFlats. I used Nitto NeoGen's in 205-50-16 (v rated) from Discount Tire.
Shipped to me with their 3 year warranty (unlimited mile) just over $400.00. They seem to hold the road really well.
I like them for the fact that they also will protect the rim, as the edge of the tire is about 1/4 outside the stock rim's furthest point. I've not had any rubbing.
BTW, with regular rotation (and pushing the limit), I got 39K out of my first set...not knowing I could replace them, I got another set and took them for 31K miles.
This past weekend I swapped out the Dunlop Run flats for 215/45/ZR17 Nitto Neogens. What a huge difference. My JCW with the JCW suspension is now a normal daily driver for me.
I will keep the MINI and forget about getting a Buick for my next car.
09 JCW Laser Blue/Black | JCW Aero Kit | JCW Suspension | JCW Steering Wheel | Akrapovic DP & Evo Exhaust | M7 CF Hood Scoop | DoS CAI | Helix Intercooler | H-Sport Rear Sway Bar | Craven Speed SSK | NM Eng Tie Bar, Boost Tubes & Torque Arm Insert | BSH OCC & Boost Tap | VEI High-Res Boost Gauge | Integral Audio Sub & Soundsatge | Blacked Out by Vinyl Styles | Pics
This size is new for Hankook ventus V4 h105
Yes and they are 192-55-16's so No speedo problems.
If you can go to Akron auto and truck tire on Annadale in Akron
the Mount and balance is only $10.00 a tire.
$408.00 out the door.
Quote:
Originally Posted by aperodeau
Hi,
Which tires did you replace your runflats with? I'm so confused by all the choices!
