Unexplainable
Old 09-25-2015, 10:08 AM
rt808's Avatar
rt808
rt808 is offline
Unexplainable
My car haven't been driven in a months due to overheating, once in a while ran the engine to keep the bettery charged but yesterday engine doesn't turn just clicking, jumper the car but having difficulties all the warning light illuminated except the battery warning light...weird though, tried several times ensuring jumper cable has good connection then finally started, drove around then the rest of the light cleared execpt the dcs and the power windows will not operate.
I decided to remove the battery and charge overnight...BTW the battery is Optima and its only 2 years old, hardly drive the car except when my son coming home from College. Today i decided to replace the Coolant expansion tank where i found some seepage from the joint in the middle, removed the socket wire connector located next to the air filter (driver side) ensuring its tight, started the car fine, power windows works fine and cleared all the warning lights, no engine code though..which surprised me, but still car overheats, i hear the low speed fan running at certain temperature but if i use the AC the radiator fan stop and the AC compressor stop as well. I am planning to evacuate the coolant i have the tools now to do it, change the harmonic balancer ( still good as of now ) but im going to replace it all at once, and solid thermostat housing....Comments are welcome. Thank You
Old 09-25-2015, 12:14 PM
ZippyNH's Avatar
ZippyNH
ZippyNH is offline
What year MINI?
S or non-S?
Which Tranny?
Hardtop or cabriolet?
Old 09-25-2015, 12:27 PM
ECSTuning is online now
Received 1,965 Likes on 1,765 Posts
Yep, model and year needed.
Old 09-25-2015, 01:28 PM
rt808's Avatar
rt808
rt808 is offline
Its 2002 MCS, Manual Transmission/hard top.
It started overheating when the thermostat seal leaking after the dealer changed it, followed by the low speed fan not working, replaced the radiator fan, changed the gasket myself and ever since its been on going issue, water pump also changed along with the new supercharger(seal leak on PTO side) done this done that, tilt the whole car and bleed the air and still same issue, the only thing i haven't done is to evacuate the system.
Old 09-25-2015, 01:33 PM
" evacuate the system" and check the thermostat they replaced. I have seen new ones stick, you can test it by placing it in a hot bowl of water and seeing the valve if it moves at the centigrade temp marked on the part.
Battery, even though its a optimum battery it will need load changed, its might be bad. Then inspect the lines going from the battery to the starter, on a 02 you might have corrosion on the starter terminals, then check the battery connection in the rear and the terminal with the little yellow/ black box on it.
Thats where I would start.
Old 09-25-2015, 01:40 PM
rt808's Avatar
rt808
rt808 is offline
Thanks ECS for the input, yeah i have a wish list in your website the thermostat housing and silicone radiator hoses those are the parts im going to replace...
Old 09-25-2015, 01:59 PM
Welcome,
Thanks for the order.
Let me know if you need anything else.
Love is Like Oxygen Blue
06-08-2014 07:17 PM
Gerldoc
06-23-2010 07:20 PM
Headlands
R55 :: Clubman Talk (2008+)
19
12-29-2009 11:52 AM
ravenofskys
03-23-2009 06:08 PM
Quick Reply: Unexplainable
