My 'Bagged R56
Old 08-21-2015, 08:42 PM
twistedimages's Avatar
twistedimages
twistedimages is offline
My 'Bagged R56
I picked this '09 Cooper S up from my dad a couple months ago- he decided a Miata was a better choice for towing behind his RV.
It was SUPPOSED to be my daily driver- something I could leave stock while I focus on building my Datsun 510. Then my buddies at Air Lift Performance announced their new kit for the R53 Minis, it got my wheels turning... and here we are!
So, air suspension, new wheels, some tint, and now I've got a daily driver to be proud of!
I've still got a few other items planned, but for now I'm really happy with my Mini. If you have any questions about my air suspension installation, let me know!
Old 08-21-2015, 10:34 PM
AZN Optics's Avatar
AZN Optics
AZN Optics is offline
Welcome to NAM! Love the slammed look
Old 08-22-2015, 07:56 PM
Beau B's Avatar
Beau B
Beau B is offline
Looks good!
Old 08-24-2015, 11:33 AM
PelicanParts.com's Avatar
PelicanParts.com
PelicanParts.com is offline
Vendor
Welcome to NAM! Very nice! We have a member (Spencer) who just bagged his R53 and doing some more fun goodies. Can check it out here. What wheels are those? They really set off your MINI's look.
888.280.7799 | 6am - 5pm PST
Old 08-24-2015, 12:12 PM
twistedimages
Thanks! They're Rota RBs in a 17x7.5, with 205/40-17 tires.
I modified the Rota center caps to accept the factory Mini caps.
Old 08-24-2015, 12:20 PM
PelicanParts.com
Vendor
Very nice! I like how you modified the center caps. You should look into doing the stubby antenna mod. I think it'd really tie in well with your MINI's look. Keep up the good work!
Old 08-24-2015, 01:06 PM
twistedimages
I've been looking at one for a bit now. Once I finish the roof graphic I'll pull the trigger!
Spencer's R53 is awesome- very clean installation.
Old 08-24-2015, 01:09 PM
Helix13mini's Avatar
Helix13mini
Helix13mini is offline
Saw it on the other site. Looks good!
Old 08-24-2015, 01:48 PM
ECSTuning is offline
Received 1,965 Likes on 1,765 Posts
Wow pretty low. How much are you below stock height. What did you mod to go low ?
We carry Air Lift for the Gen 1 in stock. Hopefully something for the Gen 2 will come out some from them.
Looks like someone moved the Cooper S emblem on the trunk to the other side and lower.
Old 08-24-2015, 02:34 PM
twistedimages
I never noticed that!
Old 08-24-2015, 02:38 PM
twistedimages
My car at full drop is approximately 5.25" below stock. I didn't modify anything on the car.
My struts are the Air Lift Performance models for the 1st Gen Mini. I machined new upper camber plates for the front, and used adapters from FastMini.net for the rear lower strut mounts- everything else bolted directly into place.
I'll be offering the new camber plates for R56 owners soon, as Air Lift doesn't have concrete plans to release a kit this year.
Old 08-25-2015, 05:16 AM
M7Speed's Avatar
M7Speed
M7Speed is offline
Welcome! Beautiful R56, very well done! Has to be the cleanest bagged MINI I've seen.
If you ever want to add some go fast parts to it, look us up!
Old 08-25-2015, 05:25 AM
Either someone moved it ( had it removed for a cleaner look ) or had something repainted and then put it down there.
Old 11-12-2015, 12:15 PM
jwmolmen's Avatar
jwmolmen
jwmolmen is offline
performance wise how well does it handle. did you lose the go cart feel or improve it. thuinking about this kit
http://www.d2racing.com/air-suspension/basic/
Old 11-12-2015, 12:55 PM
twistedimages
The car still scares me with how well it handles! I'm sure that "at the limit" I've given up some of the cornering performance, because I have the struts set to a softer setting than how the car felt stock, but it's more than enough for me.
I looked at the link you posted, and I have one MAJOR piece of advice: always keep all four corners of the car separated with their own valving! Their "basic" kit uses two valves from what I can tell- one to lift both front wheels and one to lift both rears. When you go into a corner with a setup like that, the air will actually transfer from one side to the other, making your car lean twice as hard as it normally would- probably NOT the type of handling characteristic you want!
By running four valve pairs, each corner can be adjusted independently, and no transfer will take place, giving you the best possible handling.
As for D2's struts versus the Air Lift Performance kit I'm running, I can't say what the differences are. I'd recommend a front kit with adjustable camber to keep the wheels from going positive at full drop, but other than that you'll just have to read around a bit to see how people like the D2s.
Good luck! Let me know if you have any other questions!
Old 11-12-2015, 12:57 PM
twistedimages
Woah- is that $3700 for their basic kit?!
Send me a PM- I can point you toward something a LOT better for less. Or something 1000x better for the same money! Haha
Old 11-12-2015, 01:07 PM
jwmolmen's Avatar
jwmolmen
jwmolmen is offline
pm'd
rtk90
08-29-2019 09:08 AM
dropnstylez
10-29-2015 08:57 AM
newowner
09-15-2015 07:18 AM
09-04-2015 01:31 PM
Ntety
09-02-2015 08:39 PM
Quick Reply: My 'Bagged R56
