1st post, now straight to modding..
I just got a R56 2008 Mini Cooper S in laser blue.
I am new to the Mini world, I am a long time bmw guy.. Previous cars E36 M3, E46 M3, E36 3 series.. These mini's are fun little cars to drive, how ever I am looking for a little bit more power. I'm in no way trying to build a fast car, but i would like to be in the range of 225whp without messing with internals.
After some research I decided to go with some of these mods and i'd like input from the community. Right now it's completely stock.
Intake: AEM Ram $387
Alta hot side $124 ebay.
Forge DV kit $234
Down Pipe: WMW $299
Intercooler: Forge $648
Exhaust: Alta 3” catbak $743, Borla race catbak $765, Invidia catbak $599, Magnaflow catbak $674, DDMworks catbak $780, Milltek catbak $849, NM eng. catbak $780, NM downbak $1000 I'm not sure which one yet.
Tuner: Manic Stage 2 ECU $550 plus switch $200.
Meth injection*: aquamist HSF-4 $1140 - undecided if i want to do meth tho
What do you guys think of these? anything I missed?
Forge DV kit $234
Down Pipe: WMW $299
List of mods looks pretty good! Very similar to my car. Only question I have is do you like your car to be loud? IMO those exhausts with a catless downpipe are much too loud. I went with the Akrapovic and it sounds perfect, however it is very expensive. I also recommend to add the NM-Eng torque arm bushing insert to your list. Really helps to reduce twisting of the engine with all that extra power.
Well I don't want it to be super loud but from the youtube vids of those diff exhaust, they don't sound very loud so that's why i thought a catless dp would help.. That Akrapovic sounds nice, its just about 1K more then i'd like to spend lol. I will definitely look into those torque arm bushings
https://www.northamericanmotoring.co...n-systems.html
You'd be surprised where you can find methanol. I get mine from a local fuel supply company, they supply heating oil, high octane fuel for ATV's, lead based fuels, etc.
The N14 engine (which you have) can really benefit due to the direct injection and very poor design of the PCV system. The PCV tends to introduce excessive amounts of oil back into the intake which builds up carbon on the intake valves and decreases octane and can lead to burnt valves and broken pistons. The methanol can help combat this, which is really important at elevated boost levels.
If you install a methanol kit you can continue to use the factory intercooler.
check out gpop shop for their K04 upgrade. its a direct bolt on install. then look for a down pipe. give the boys a call for An ECU Flash, or take it to a local shop to have them due a custom program for your car. make sure you get a copy of it, if you ever have to re flash the thing..
That's a great list of drive train mods. I'm in the process of doing a few of the same ones to get ready for my Manic Stage 2 tune. I'm running a DOS intake and the Forge Diverter Valve. I'm going with the Wagner Tuning Intercooler but I'm up in the air with the exhaust. I was thinking on a WMW catless downpipe with my standard exhaust. Will that be a problem, such as drone or lack of power gains? If I bite the bullet and go with the Akrapovic, can I go just with the Akra downpipe or do I need to go with the whole system? Ditto on the Torque Arm insert.
Don't forget to turn the car too!
Hotchkis Rear Sway Bar. Get the Hollow 25.5mm.
NM Torque Arm insert or the PowerFlex small insert (requires press).
Control Arm Bushings.
BSH Clutch stop <---- This is an awesome bang for buck. Totally changes the clutch operation feel.
Change those wheels! The current wheels you have on are one of the heaviest wheels (if not the heaviest) MINI made. I think they are around 23lbs a pop. My NM wheels are 16lbs. Thats a pretty substantial unsprung weight savings that can make your car faster w/o doing anything to the engine.
If it has runflats, get rid of them now!!! Replace them with a nice set of all seasons. Or if you're really ready to go a nice summer only such as Micheline Pilot Super Sport or a Continental DW. You'll be suprised by the huge increase in grip when you do. Not to mention better ride comfort.
I'd recommend going to a 215/45R17 tire size as well.
Thats it for now, before I get too long winded
If yall are able to spin a wrench. You can always look on ebay for CKOs. Most of the piping or intercooler are cheaper. Name brand is only needed with big ticket items.turbo and ecu flashing. I'll be around 250 hp and under 1500. I'll also have a spare MCS turbo with under 40xxx miles on it for sale. So I'll recoup funding there also.
"I was thinking on a WMW catless downpipe with my standard exhaust. Will that be a problem, such as drone or lack of power gains?" I had the same question?!!?! How do you like your Forge DV??
My next things on the list will be that clutch stop Grizld700 recommended. then the boost tube and FMIC. I am waiting for the wheels as i still have plenty of tread left on the current tires, when those go i will replace both. Still not sure which ones to go for though. I want some type of Gun metal finish.
BTW, heres the installed AEM intake
I had a DDM intake for a while, which is similar to the AEM but had an issue with the vacuum hose collapse/brake failure so I switch tot the Defenders of Speed intake. I installed the Forge DV at the same time and the butt dyno really likes it. I feel better throttle response and the power at 4000 - 6500 rpm is real strong. I put the clutch stop in months ago and for a $10.00 mod, it's a must.
Also a heads up those in Hot summer climates have had some issues with the AEM Turbo Heatshield trapping the heat and melting the valve cover. These cases have been few in reports, but they have happened. I ran mine all last summer with no problems, but it was a pretty mild summer here last year.
