Belt size for 17% pulley + 2% crank pulley
Alta has a table for beltsizes....
imo it is not 100% correct, cause the last time i looked, the suggested belt size for the 17% was larger most most folks use....the one they list is ok when new...
Going for a the equivelant of a 19% reduction! Bet it will be a screamer in town at lower rpms! Just hope you don't start to hit codes due to max fuel flow cutoff at larger throttle inputs...but i know some runers can fix that.
Sounds like rmw is retuning it? Or just getting a new belt?
...actually with a -17, and a +2, he needs a LONGER belt than with just a -17.....so i bet the 532 will be too tight...it is snug on a -17, without a bigger crank damper....539 might still be too snug....guess that is why he is asking....and i defered to alta...
gates: #060539 = 1385mm = ok for stock OR w/ 15% pulley or 17% pulley
gates: #060535 = 1379mm = best w/ 15% (and with either the 0% or 2% crank pulley)
https://www.northamericanmotoring.co...17-pulley.html
M7Speed
09-03-2015 07:48 AM
